I'm having exactly this person's problem:
https://forum.videohelp.com/viewtopic.php?t=282510&highlight=menu
I was certain that this solution would work for me, since my highlight and normal colors were both red. However, after changing the highlight color, the highlighted selection still appears well below the normal color on a standalone player. On the preview everything works fine. When attempting to watch the DVD via software, the highlight text appears normal, but in order to choose a different button I have to hold the cursor well below where the button appears on the screen. Does that make sense? Any thoughts/ideas?
Thanks,
Ben
Ok. Can you create a DVD with a menu using the following dummy movie files: http://www.svcd2dvd.com/samples/dummymovies.zip
Before authoring can you do a menu preview. Whilst the preview is still open can you copy the menu folder: C:\Program Files\BadgerIT\SVCD2DVD v2\menu to somewhere as i will need to see this and it gets deleted once the preview is closed.
Create the DVD and make sure it exhibits the problem.
Then can you email me the VIDEO_TS folder, the log, the project file and the "menu" folder?
I will investigate.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Video Cards revisited
By Seeker47 in forum ComputerReplies: 7Last Post: 24th Oct 2011, 11:32 -
AC-3 and Wave 5.1 frustration revisited...
By takearushfan in forum AudioReplies: 32Last Post: 19th Aug 2010, 14:54 -
MTS2AVI revisited
By RogerTango in forum Video ConversionReplies: 35Last Post: 28th Jun 2010, 17:08 -
DvdAuthorGui Menu Jump & Highlight problems
By grannyGeek in forum Authoring (DVD)Replies: 5Last Post: 24th Jul 2008, 23:26 -
Blank media revisited
By didikai in forum Newbie / General discussionsReplies: 3Last Post: 1st Jun 2008, 10:57
