hi everyone.
i know theres some clever people on here,wondered if i can have your help please.
i have 2 avi films,one is excellent picture,but foreign sound,other is poor picture,but english sound.
in laymans terms,what would be the best way to extract audio from 1 and pic from other and then combine them?.
am i right in thinking this would be very technical?i.e getting audio and pic in synch etc.
thanks in advance for any help.
Results 1 to 16 of 16
virtualdubmod. Demux the audio from the avi with the good audio. Load up the avi with the poor audio and add the demuxed audio as a new stream. Disable the other stream and use Direct Stream Copy to write the results to a new file.
This will only work if the audio is the same length, that any delays are identical etc. Otherwise you may have sync problems that you will have to correct.Read my blog here.
Hi shamus,
Load the AVI with the good audio into VirtualDub. Save the audio out to a WAV file - this is easily done: File -> Save WAV...
Now load the AVI with the good video, and select the saved WAV as the audio source: Audio -> WAV Audio... -> Select saved WAV file.
Save this arrangement of AVI and WAV:
1) Video -> Direct Stream Copy
2) File -> Save As AVI...
That should do the trick.
EDIT: I had this thread open ages ago, and finished off my reply just now - guns1inger replied in the meantime. Same principal, nearly the same method just a different variant of the same tool.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Originally Posted by guns1inger
I started on a reply as I knew I could help, but had to dash out to several meetings - I left the reply "mid sentence" and finished it when I got back.
In the meantime, you slipped one in... A bit like Shane Warne
Carpe diem.
I'm glad he types slowly - I can't read very fastOriginally Posted by guns1inger
Hi,
Will this method work with .vob files? Can I save the dubbed ones as .vob? Or, do I have to convert .vob files to .avi?
Thanks -
Thanks Guys,I will give it a whirl and post back the results.
Thanks a lot. -
ok daamon,idea worked easy peasy lemon squeezy,it merged good audio and video just like you said.
only problem now is dubbing is way out
.any ideas what i can do next?.
If the audio is out of sync I would suggest you have different delays in the two files. You need to determine the delay of the new audio, and use either ac3 delay corrector or your authoring app to adjust for it.
Read my blog here.
hi guys,here is the info that ABOND asked for,if ive done it correctly?
FILM 1(GOOD AUDIO)
type AVI,
25.000 FPS
1059kb/s BITRATE
AUDIO 192kb/s(96/ch,stereo)CBR Fs44100Hz MPEGLAYER3(MP3)(0x0055)
FILM 2(GOOD VIDEO)
type Open DML AVI,
25.000 FPS
1249kb/s BITRATE
AUDIO 192kb/s(96/ch,stereo)CBR Fs48000Hz -
ok
FILM 1(GOOD AUDIO)
I/L 1 vid frame (40 ms) Split: Yes
FILM 2(GOOD VIDEO)
I/L 2 vid frames (80 ms) Split: No
FILM when i have combined the good audio and video
Must admit im getting a bit lost now
Im sure you guys are about to make things sound simple though?
cannot see or extract audio from AVI
By Srivas in forum Video ConversionReplies: 6Last Post: 8th Dec 2011, 00:47 -
By Srivas in forum Video ConversionReplies: 1Last Post: 7th Dec 2011, 02:49 -
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 24th Jan 2011, 00:28 -
How to extract audio from a VCD?
By c1steady in forum AudioReplies: 2Last Post: 14th Jan 2010, 21:16 -
Extract audio only from VCD
By ambrosechapel in forum AudioReplies: 2Last Post: 19th Aug 2008, 22:24
hi everyone.
