I'm liking the way the app works for me in general, but I'm running into a lot of the files that show up in assets with hugely negative durations, and of course don't end-up working. Earlier, we had discovered that it had something to do with sound style changing during a cut to a commercial. I have found that it happens in the middle of a show.
What I've done to get around these glitches is a royal pita, but it works. I use HDTV2MPEG2 to split the file into 5MB chunks (hundreds of them, of course). Then drag all of those files into the assets, except for the one that has a sound glitch.
I would LOVE it if there were additional robustness added to get through the glitch. Now, if the expense would be sound synch off at the end, I'd say NO WAY! I'd much rather have a missing segment than to have synch problems. But if it were possible to fix this without risking synch, I am at your service to deliver chunks that have the negative duration problem.
--Dale--
Ok. Can you upload 3 files to start with: chunk before glitch, glitch chunk and the chunk after glitch to ftp://BetaTester:badger@ftp.svcd2dvdmpg.com:7676/sengsational/
I'll see what can be done.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
actually can i also have the first chunk and the last chunk too plus your log of a run of the large file on its own (no need to complete the run just get it started so i can see the duration estimate)
ThanksSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Various audio durations to video
By mrcoolekin in forum AudioReplies: 3Last Post: 17th Jun 2012, 18:41 -
VOB Files Change Durations!?
By ronsweet2 in forum Newbie / General discussionsReplies: 5Last Post: 6th Jun 2009, 03:09 -
Irregular TV program durations - an effort to defeat DVRs?
By ebenton in forum DVB / IPTVReplies: 2Last Post: 13th Feb 2009, 20:30 -
negative print
By devdev in forum EditingReplies: 2Last Post: 27th Jan 2009, 08:23 -
How do I get exact durations?
By bratpop in forum DVD RippingReplies: 7Last Post: 19th Nov 2008, 14:08
