I have a Image, it plays prefectly fine on my computer but when I got to burn the image to DVD it comes up choppy on my TV. Why does it do that and how can I fix it?
Thanx,
Stoked
Stoked
Without any real details being provided, I would say crap media is the cause. Other possible causes include the bit rate being too high, and crap media.
How can you fix it ?
1. Only buy good media http://www.nomorecoasters.com is a good starting point
2. Tell us exactly what you did to create the disc
3. Read the What is DVD section at the top left of this site, then make sure yours compliesRead my blog here.
Most video files will play fine on a pc because a pc can play any framerate .
Dvd player's dont .
I would check what the framerate is first using a few tool's available here onsite in the tool's section .
Dose your player support the playback of both Pal and Ntsc format . -
I don't think it supports PAL. And which program should I use to check the framerate. and what should be the right framerate.
Stoked
Windows7 image backup - restoring the image question
By ranchhand in forum ComputerReplies: 18Last Post: 15th Apr 2012, 08:13 -
Question how to image and restore netbook from dvd
By jimdagys in forum ComputerReplies: 7Last Post: 27th Nov 2011, 10:23 -
Sorry for the Rudimentary Question...DVD image not happening.
By stratojbear in forum DVD & Blu-ray PlayersReplies: 7Last Post: 23rd May 2011, 11:06 -
DVD Video Image Oversized Question
By JerryRecords in forum Video ConversionReplies: 3Last Post: 21st Dec 2008, 12:14 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 05:29
