Results 1 to 10 of 10
  1. Video Restorer lordsmurf's Avatar
    Has anybody done this, and gotten it to burn DVD-R fine?
    Lansing Michigan USA
    I have burned a few DVD-R and DVD-RW with my converted Dell 1100A to 1300 and everything has been fine. Although I mostly use my 3520A simply because it offers faster speeds and Dual Layer capabilities.
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    I have a secondary NEC-1100A.
    All ears.
    http://www.kiva.org/about
  4. I did it, worked fine, -R and -RW, but I don't have it anymore.
    I used herrie firmware.
    Dec 2002
    Costa Rica
    The Dell I used to have had a NEC that I x-flashed to NEC 1300. It worked very good for me. A frien of mine had the very same machine with the same drive but his NEC 1100 was never able to -R media. no matter what firmware we used.
    I would say the x-flasing will work most of the time, but there will be some unsuported drives out there.
  6. Human j1d10t's Avatar
    Feb 2003
    California, USA
    How would you go about doing this? I'd be very interested in getting my 1100A drive to burn -R..... Some instructions would be nice
    "Don't try to be a great man. Just be a man, and let history make its own judgment."
    Zefram Cochrane
    2073
  7. Check out the NEC forum at cdfreaks:
    http://forum.cdfreaks.com/forumdisplay.php?f=86
    Plenty of info on flashing bios to upgrade NEC drives with feedback on what works....and what doesn't.
    -drj
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
    --Benjamin Franklin
    Oct 2003
    Grovetown, GA
    Greetings,
    I did the conversion more than one year ago and it runs without almost any glitch on +-R, +-RW.
    The only issue I am having since the conversion is sometimes DVD Decrypter issuing an error msg at the beginning of the burn. The trick is to reboot my computer.
    It is unfortunate with +-R because the disc is wasted, but for the +-RW I don't lose the disc.
    Thank you
  9. Human j1d10t's Avatar
    Feb 2003
    California, USA
    -drj
    Thanks for the info - I flashed mine and now it just burnt a -R with no problams. I'm going to pick up some -RWs and see how they work, but I mainly wanted the -R ability, so I'm happy Just saved me some money since I don't have to go buy a new +/- burner
    Zefram Cochrane
    2073
  10. Video Restorer lordsmurf's Avatar
