    Jan 2006
    I know that I can create the chapters manually but I just want to have chapters created automatically every 7 minutes or so. Is there a way to do this? If so, how? Thanskf or any assistance.
  2. Banned
    Sep 2005
    USA
    When you finalize the disk, the Panny will generate chapter breaks. You won't have a chapter level menu to bring up, only a title level menu.
    Jan 2006
    so what that really means is that I will be able to skip ahead in x amount of time increments correct? So if i want menu chapters I will have to manually make them?
  4. You could create a playlist.
    Jan 2006
    Yes, but I was looking for a real quick way of recording. If I create a playlist I would have to create the chapters manually, right? All I really care about is having 7 minute or so jump points int he movie.
  6. Banned
    Sep 2005
    USA
    dolfan, If you want this on a finalized -R DVD, the Panny will generate the fixed time interval chapter marks so you can advance 5 minutes at a time. You will not be able to display a chapter level menu. The Panny only supports creating a title level menu. That is why I now do all my editing, authoring and finalizing on a PC. The authoring software I use allows me to create chapter level menus, with motion thumbnails, under the title menu.
    If you are leaving the material on the hard drive on the recorder, then you can still see the thumbnailed chapter level menu but you will have to manually insert the chapters.
    Jan 2006
    Alright. That's what I was wanting to know. Guess I will be doing it your way if I want chapters on my menu then. Thanks.
