I have two machines. On my faster one, none of the capture programs will work without stopping after a few minutes. (8mm camcorder to computer). So I tried my slightly slower machine. I turn off everything I can think of and disconnect from the web. On this machine I get a complete caputure, but it jerks and stops along the way just as the previews show. I turned off the preview in one program and it made no difference. I have used Windows Movie Maker, Roxio, Nero and on of the major Movie Caputure programs. Thank you.
Results 1 to 17 of 17
sussertown
I am using a Syba ALI combo card (Firewire and usb2). I wondered if this could be the issue. Someone suggested not likely. Both machines have the same card.
sussertown -
Also, is this a Digital8 camcorder? Is this a DV transfer?
Also describe the two computers.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
It's a digital 8, however the tape may be just 8.
Bother are AMD 1600 or close to it. The smaller one has 512mb and the bigger one has 1gig.
They both have 128mb of nvidia video memory on a card.sussertown -
Originally Posted by sussertown
Normal 8 loads the computer the same as DV. Not a problem.
AMD 1600 somewhat adequate. Memory is adequate.
Add more detail.
Describe hard disks and amount of free space.Recommends: Kiva.org - Loans that change lives.
I have plenty of space. double 160gb drives.
Much free space. I typically select E:\temp for buffer.
I use fixed virtual memory of about 1800 to 2000mb on D:\sussertown -
On the slower machine, the one that recorded but stopped and jerked, I have a 40gig on the back (F:\), but there is still plenty of room. I am suspicious of the condidtion of this drive. It occasionally makes a little squeal.
sussertown -
normal advice cap to second drive, shut down background processes and antivirus while transferring.
It should work.
What a let down. I thought we were going somewhere. I could have told you "It should work."
sussertown -
You have eliminated most everything but the source and the capture device. What's the source you are capturing?
Okay, let's start over. I eliminated most of the brain damage from the last 4 years. I now own a stand-alone recorder. I recorded from my 8mm camera. It made a good recording onto RW. Now I'm going to edit it in Video Studio 8. The problem is that VS8 doesn't understand AC3. So I guess I need a plugin. I'm now trying to figure out how to put a pluging for this purpose in VS8. I don't see a plugin folder other than individual visual arts stuff. I wonder if I can just download a free AC3 fliter and get it to work in VS8.
sussertown -
ULead used to sell the AC-3 plug-in for $29 but it is now standard in VS9. Better to upgrade for the other features as well.Originally Posted by sussertownRecommends: Kiva.org - Loans that change lives.
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 10:41 -
Can't Caputre MiniDVDs.
By menash07 in forum Capturing and VCRReplies: 1Last Post: 26th Jun 2010, 18:50 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 04:18 -
Looking for some good instrumental music that would be good for football.
By ingeborgdot in forum AudioReplies: 8Last Post: 26th Nov 2007, 22:18
