Recently, I am having some problem with my firewire transfer. When encode to MPEG2 and author to DVD, I notice that fast viewcam movement from left to right and top to down, there will be several horizontal bands that flicker(laging).
Is this a PC or videocam problem ? By the way, just sent the viewcam for service, and the tape loading mechanism was replaced.
Results 1 to 9 of 9
DV file transfer is just that -- check your footage before capture & after transfer to see if source has prob.. If source looks good, then prob. is likely downstream during editing or encoding phases. If it shows prob. after transfer only, then maybe that's the prob.?
Thanks. I have not change any process from encoding to authoring. The problem shows up during playback on TV. I will try capture with my brother's Sony Camcorder and see if the problem is there.
BTW, the problem goes away when I transfer using my LG DVD recorder via composite input. -
sorry, somebody can informal me the number of the serial one of camera Sharp VL-Z950 viewcam?
@aitian,
Not sure why you need the serial. I will let you know the first seven, E404611XXX. I mask out the last 3 numbers. -
it is the serial one for the installation of the program in the computer
@aitian,
I never use the program in the CD. This is the serial # on the video cam.
@guns1linger,
It's on the TV. PC plays fine. -
If you see that on TV, then it is a camcorder problem. The problem looks like interlace related, and the PC DVD playback software managed to deal with it.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 15:56 -
Capture Sharp Viewcam Hi8 with WinTV-HVR-1800
By Rotramel in forum Capturing and VCRReplies: 8Last Post: 20th Apr 2008, 09:25 -
Help! Wierd problem of Sharp Aquos 46D64U
By cryogenics in forum DVB / IPTVReplies: 3Last Post: 3rd Dec 2007, 23:56 -
Problem , sharp video ???
By ZaYoOoD in forum Software PlayingReplies: 1Last Post: 23rd Oct 2007, 11:32
