I'm having some trouble burning an AVI to a DVD:
First, I encode it using tmpgenc 2.5 for DVD NTSC which, at a bitrate of 4700, 720x480 gives just under 4G.
When I go into DVD Author 1.6 select the source, it says this will take up almost all of a 4.7G disc, which is fine. I encode
When I get to Nero 6, Nero shows me that this will occupy only HALF the disc, and sure enough, when I burn it, a visual check of the back of the disc shows about half-used.
I tried to DVD author two such files, but Nero went WAY over the limit and wouldn't burn. What is happening?
Is one of the sizes being reported wrong? Could I fit two such things on a disc, or perhaps 1 with better resolution?
Something's going amiss with Nero. I'd suggest you're not using Nero Burning ROM and the DVD-VIDEO template, or you're not adding ALL of the files in the VIDEO_TS folder.
If in doubt, Google it. -
So TMPGEnc DVD Author tells you almost 4.38GB then you bring the VIDEO_TS folder into Nero and it only takes up half the disc ?
After you have TMPGEnc DVD Author write out the VIDEO_TS folder ... what is the size using Windows explorer?
Also when I use TMPGEnc DVD Author I have it write out the VIDEO_TS folder as it does then I use it to create an ISO file then I burn that ISO file with ImgBurn. I don't understand why you would use NERO ... puke
DVD Recorder Captures at Wrong Size
By MasterOfPuppets in forum Capturing and VCRReplies: 3Last Post: 22nd Feb 2010, 21:51 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
Wrong image size ratio after AVI to DVD encoding
By video34bgi in forum Video ConversionReplies: 2Last Post: 22nd Jun 2009, 11:45 -
TMPGenc DVD Author 3 Maximum Size
By Shadowofthedarkgod in forum Authoring (DVD)Replies: 5Last Post: 6th Apr 2008, 19:59 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 18:53
