    Jan 2006
    Hi there, I'm relatively new to encoding on a Mac - I tried to convert a .avi (DIVX) 624x256 12bpp 23.976 fps 622.4kpps -
    to a dvd ffmpeg - mpeg2 720x480 4000 kbps 23.976 fps
    Quicktime is decoding - the output is autosized to DVD 16:9 framerate NTSC film
    Anyway - I ran the encode and the following files came out
    title.mpv - about 3gig
    title.ac3 -
    title.mpg - about 3 gig
    title.mpg.DVD folder containing AUDIO_TS and VIDEO_TS
    BUT
    VIDEO_TS contains only VTS_01_1.VOB which is about 19mb ???
    I can't play that VIDEO_TS file thru apple DVD player
    quicktime plays the .mpg without sound (even though QT A3 codec is installed)
    VLC plays .mpg no probs with sound - also plays the VTS_01_1.VOB which is about the first 5 minutes of the film
    Questions: Can I just throw away title.ac3 and title.mpv as I assume they are the demuxed audio and video?
    Where did the rest of my VIDEO_TS file go?
    I tried deleting the title.mpg.DVD and then reauthoring the .mpg file in the ffpegX tools -> author section and it produced another title.mpg.DVD file with exactly the same problem
    Any ideas? - Also can i change the .mpg into a DVDr format?
    thx in advance
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    This is to be expected; the AC3 codec doesn't decode audio in muxed MPEG files, as the codec was intended for AVIs.
    Don't. Using these files will save you some time (see below).
    The log might mention an error for abortion of the authoring.
    Your source is 23.976 fps, which needs a "3:2 pulldown"-setting to be DVD compliant. So rename mpv to m2v, use the Pull Tool on the m2v, then Mux (with Author checked). Test in Apple DVD Player again.
    Jan 2006
    thx for the help, retried it and it worked fine, just a couple of Qs:
    when i drop the .avi file into ffmpegx and select dvd ffmpeg as the output source, the output framerate shows as:
    ffmpeg mpeg2, 720x480, 4000 kbps, 23.976 fps, no crop
    Is this already DVD compliant, or do i need to change it to 29 fps?
    if this is the case, is there an option to change the frame rate to 29 in the initial encoding?
    thx
  4. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Neither, afaik.
    - Use the DVD mpeg2enc preset, then you can turn on "Set 3:2" in options, or
    - Use the DVD ffmpeg preset, which unfortunately doesn't have such an option, then use the Pull tool to set 3:2 pulldown on the m2v, then mux, as described before.
    Maybe future releases of ffmpegX will simplify this process...
    Jan 2006
    thanks again, appreciate all the help
