Hi, I was wondering if anyone can help me out, I am trying to work with some files that I have seperated .m2v and .ac3 files. I would like to remux them back together and I also have multiple files, I would like to try to stitch them back together as 1 meg file. I can load the asset for the video files, but it will not let me load an audio file with .ac3 extention. Is there a way to do this with svcd2dvd? Or am I missing something.???
Thanks in advance.
Lugz
You will have to mux them outside of SVCD2DVD first.
Plenty of tools in the "Tools" section that will mux video and audio streams but you could simply run the following command line (from the folder with your files in):
where in.mpv and in.ac3 are your streamsCode:"C:\Program Files\BadgerIT\SVCD2DVD v2\mplex.exe" -f 8 -o out.mpg in.mpv in.ac3
MKV files with Audio in DTS need to convert audio to AC3
By THEHNIC in forum AudioReplies: 5Last Post: 3rd Jun 2011, 09:17 -
Opening .ac3 audio files in Sony Vegas?
By Thunderhead2772 in forum EditingReplies: 1Last Post: 18th Jul 2010, 21:55 -
AC3 (5.1 audio files) and PCM 96/24bit stereo audio files
By joannes in forum Authoring (DVD)Replies: 2Last Post: 9th Mar 2010, 16:48 -
How can I extract AC3 audio from VOB files?
By Sean_ve99 in forum EditingReplies: 6Last Post: 1st Oct 2007, 05:56 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 09:44
