Just recently, while ripping my DVDs for backup onto various DVD±Rs, I have found that my reader drive has lost speed badly. The speed in DVDDecrypter maxes out at 1.6X-speed or thereabouts, making rip times frustratingly long (by comparison, the GDR8163B I use would average at about 7X-speed before).
I have not installed anything other than Virusscan (McAfee) updates, so I do not know what the hang could be wrong. Suggestions would be very appreciated.
Results 1 to 10 of 10
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
Yeah that's what I was thinking the drive IDE channel is no longer in DMA mode.Originally Posted by guns1inger
I am fairly certain it has not, but I will check and make sure. Where do I find this setting again? (Memory like a sieve, I have.)
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
Incredibly, the secondary ATA channel's secondary port (I am paraphrasing a bit here) had been set to PIO. Without my knowledge (and noone else uses my computer). Talk about a worrying event. I will give the drive a go now and let you know if that solves the problem. Thank you.
Okay, now it appears I have a problem. I have changed the setting to DMA if available but its current transfer mode is still PIO.
Nilfennasion wrote:
I had something like happen to me recently. After googling I found out that there is something in XP that will change DMA to PIO if there are repeated failures on a HDD or a CD/DVD drive. BTW if you can not get it to stay set to DMA just delete the offending IDE channel and reboot. The system will re-install the deleted IDE and that should fix it.Incredibly, the secondary ATA channel's secondary port (I am paraphrasing a bit here) had been set to PIO. Without my knowledge (and noone else uses my computer). Talk about a worrying event. I will give the drive a go now and let you know if that solves the problem. Thank you.bits -
Ah yes, good ol' Windows XP assuming it knows better than I do how I should set my DVD-ROM.
Thank you for the hint, I am in the midst of executing it right now.
It only seems to affect drives on the secondary channel. My MB won't detect the DVD drive on the first boot, so I always get PIO mode first time. My choices are either reboot from the XP login screen before logging in, or use this little Dell utility http://ftp.us.dell.com/fixes/PIOtoDMA.exe which saves the whole delete and reboot bullsh&t. Only works for the secondary IDE channel, and it wil set everything on that channel to DMA Mode 2
Read my blog here.
Fortunately, this is the first time in over a thousand uses that I have had this problem with the drive, so I think I am safe to let this go. I seem to have the problem solved now, so thanks to all and sundry for your advice. I do not know where most of us hobbyists would be without this site.
Rip DVD's without quality loss - is it possible?
By Rolf212 in forum DVD RippingReplies: 9Last Post: 4th Oct 2012, 19:17 -
Sudden audio loss on avi file
By jruston in forum AudioReplies: 0Last Post: 16th Oct 2010, 15:55 -
Critical Speed Loss
By saurio in forum DVD RippingReplies: 2Last Post: 21st Jun 2010, 15:17 -
How To Rip A CD To Lossless Format And Burn To CD Without Any Loss Of Quali
By Nitro89 in forum Off topicReplies: 13Last Post: 9th Aug 2009, 19:43 -
AMD issues dramatic price cuts for triple-core CPUs
By joytimeday in forum ComputerReplies: 2Last Post: 12th Oct 2008, 18:35
