Hi,
I have some DVDs that are about 1.5 GB each. I want to make copies and put 3 DVDs into one. What is the quickest way to do that? Thanks.
if you're not interested in keeping the main menu's, you can use dvd decrypter and rip the streams and author to dvd with TDA.
if you want to keep the menu's, i suggest dvdremake. -
DVD Remake (payware) allow you to import up to 4 dvds to one and make your own Main menu. I belive....
The long way is pgcedit with some others tools. There are guides for both methots.I want to believe.... -
Hi unplug,
Do each of the three DVDs have menus? And, if so, do you want to keep them? This info will help to identify a suitable approach.
Also, 3 x 1.5Gb = 4.5Gb but single layer DVD discs only hold around 4.3Gb. You'll need to figure out a more accurate sum total. If it's close to or exceeds 4.3Gb, you'll need to shrink it a bit.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
https://forum.videohelp.com/viewtopic.php?t=284279
I like DVDRemake Pro for this.If in doubt, Google it.
multiple DVDs to BD-R?
By Sephiroth666 in forum Authoring (Blu-ray)Replies: 13Last Post: 26th Feb 2009, 18:42 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 17:29 -
Multiple DVDs in one DVD
By src2206 in forum Authoring (DVD)Replies: 2Last Post: 18th Feb 2008, 10:09 -
multiple dvds
By selbing in forum EditingReplies: 1Last Post: 13th Oct 2007, 02:42 -
Multiple DVDs/VOBs...
By takearushfan in forum Authoring (DVD)Replies: 6Last Post: 26th Aug 2007, 05:39
