Hi,
I followed a guide and used VOB2MPG to rip a (approx) 7.5 gig DVD to an MPG file. It was off an older disc that was scratched to hell and took lots of tried and cleaning to do.
I ripped the disc to my HD first with DVD-Decrypter so I still have the image in case I have so far not taken the right action. I mounted the image to a virtual drive then ripped it to an MPG with VOB2MPG. Now I want to do a full re-encode to get it to fit on one DVD-5 disc at the absolute best quality. I already tried DVD-Shrink but the quality is horrible. I have done some other work with Encoders and hope I can get a better quality copy by re-encoding rather than transcoding.
Am I on the right track?
I tried loading it into TMPGEnc but it loads the file as a video source only and when I demux the file it does not recognise the files in order to re-encode them.
What can I use?
Thanks,
J
DVD Rebuilder Pro, re-encodes using free encoders like HC and can be used with Procoder and CCE. Takes longer than transcoding but well worth the extra time. The Pro version is well worth the $10 - $15.
bits -
Actualy I tried using this to re-encode the image and the disc is made was unplayable on my, several, dvd player.
I will play around with it more.
~j -
joelore wrote:
In the ISO Output Options I select to have it burn using ImgBurn or DVD Decrypter. DVD Decrypter may not be available any more but I know ImgBurn is and it is free. All you need to do is have ImgBurn installed on your system and DVD RB will find it and use it to burn the DVD.Actualy I tried using this to re-encode the image and the disc is made was unplayable on my, several, dvd player.bits -
OK, it worked great. But I must not have a setting properly set because even though I have one click backup checked it keeps bringing up a window waiting for me to click encode for every file. What am I missing?
~j
getting MediaCoder to copy audio during mkv to mpg encode?
By MilesAhead in forum Video ConversionReplies: 0Last Post: 15th Dec 2010, 03:47 -
DVD ripped subtitle file conversion
By dbarrett in forum DVD RippingReplies: 2Last Post: 17th Sep 2010, 12:55 -
Converting Ripped Blu-Ray VC-1 Codec to MPG or AVI
By MisterZJ in forum Video ConversionReplies: 12Last Post: 24th Aug 2009, 14:12 -
Subtitle sync. to CC ripped from TRP file
By vanderbog in forum SubtitleReplies: 4Last Post: 22nd Aug 2008, 23:03 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
