I bought the Coby DVD player shown in the topic for a cheap second DVD player for my rec room. It worked initially, but now it has trouble playing certain DVDs.
On several DVDs it will not be able to select chapters or play past a certain point (usually about 50%-70% through the movie). It simply pauses and will not respond to fast forward or chapter forward commands, whereas chapter backwards commands still work fine. Also when selecting chapters from the original menu it will not let me select a chapter at or past that point.
- I'm not sure if this problem is isolated to dual layer DVDs or not, but this occurs with store bought brand new DVDs.
- DVDs that have this problem play perfectly with no skips or pauses up until the point of trouble.
- DVDs that have this problem play perfectly all the way through in my panasonic DVD player.
Any ideas out there? If this IS a problem with dual layer DVDs, is this repairable? I'm unfortunately just out of the warranty period, but it was a pretty cheap player anyways.
Results 1 to 1 of 1
website malfunctions
By JohnnyBob in forum FeedbackReplies: 3Last Post: 28th Dec 2009, 03:57 -
Coby DVD-288
By manishkumar in forum DVD & Blu-ray PlayersReplies: 4Last Post: 4th Oct 2009, 22:07 -
Coby DVD-233 region free?
By grizintheworld in forum DVD & Blu-ray PlayersReplies: 9Last Post: 10th Mar 2009, 09:07 -
coby dvd 283
By bwisittalaga1 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Aug 2008, 16:58 -
Help with COBY - DVD 217
By BIFFtheSTIFF in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Aug 2007, 07:52
