I am trying to backup my flight plan dvd with 1clickdvd and also tried dvdxcopy. I get an error on each and I am not sure why. On 1clickdvd I use dvd43 v3.7.0.113 and 1clickdvd is version 4.2.9.2, I get the error on this right after I click start "error: a read error has occurred while reading a file. the file may be encrypted or cannot be read correctly by the dvd device. If you are using a decrypter you may need to restart it. I restart the dvd43 and still same error. On dvdxcopy it get 34% done the a sector 0/16 error.
Help arghhh
Maybe the newer ArCoSS encryption? Have you tried DVDFab Decrypter? Use the latest version. If you can get it on your hard drive, then you can used your preferred program to back it up.
Ok, thanks. I have downloaded it and installed and ran it. It said finshed, what do I do now? I though change the source and the destination paths but not sure. How do you do this? Is there a way to use it with 1clickdvd?
How do I make a short flight sim film/video?
By TerryW in forum Newbie / General discussionsReplies: 3Last Post: 12th Aug 2011, 15:04 -
need dvr without subscription plan
By dvdnewbie64 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 15th May 2011, 21:20 -
Do you plan on shopping on Black Friday?
By yoda313 in forum PollsReplies: 59Last Post: 2nd Jan 2009, 14:15 -
Do you plan your filming or do you just wing it?
By yoda313 in forum PollsReplies: 17Last Post: 30th Nov 2008, 19:05 -
flight route.
By PeterK in forum Off topicReplies: 8Last Post: 28th Jun 2007, 15:29
