Since we've been discussing USB to IDE Cabling I figured I'd ask if anyone has successfully made their own USB to Parallel (DB25) cabling. Anyone have directions on how to do this?
You can convert from USB to Parallel, but not the other way around.
TANSTAAFL -
http://catalog.belkin.com/IWCatProductPage.process?Merchant_Id=&Product_Id=20651Attach your parallel printer through a USB port, and leave your parallel port available for parallel scanners or cameras.
Exactly. Anyone here ever make their own home made cabling to do this?Originally Posted by lumis
I suppose you could make your own cabling, but since there will be more data pins involved on the parallel side than the serial side, it IS serial after all, you would need special components. After costs, time, and effort are factored in, it would be cheaper just to buy the cable.
TANSTAAFL
need help cabling digital tv audio out
By downriver in forum AudioReplies: 1Last Post: 8th Dec 2010, 14:26 -
video cabling
By rojoshb in forum Newbie / General discussionsReplies: 2Last Post: 2nd Sep 2009, 18:12 -
Any reason to continue using my parallel printer cable?
By zzyzzx in forum ComputerReplies: 25Last Post: 19th Jun 2008, 06:51 -
Cabling between Cable/DVD player/TV
By rszanti in forum DVB / IPTVReplies: 2Last Post: 23rd Oct 2007, 01:21 -
S-Video to Component cabling
By puzzledbytech in forum Newbie / General discussionsReplies: 21Last Post: 9th May 2007, 07:20
