When I burn certain movies to DVD-R or CD-R I am having problems with the playback on my TV. The video is very streaky and when something moves on the screen they leave behind a trail. Basically an unwatchable movie...
I am using a Philips DVP642 and most of the movie work.
This is only in regards to movies I am downloading.
Thanks,
J
Results 1 to 11 of 11
So you're not going to tell us what format those movies are, what codec did those movies use, what resolution they are, or any other information about them?
Would be kinda hard to help you if you don't... -
Need more information!
Most downloaded movies are very poor to begin with!bits -
If downloaded from filesharing sites these movies are typically recorded from a PAL source which do not show up correctly on NTSC equipment. You will get a b&w pitcure, streaking colors, ghost imaging and so on. Where's your source for these movies?
The DVP642 and other ESS based players have problems with CQM's, but then DivX can't encode using CQM's. Perhaps your file was compressed with XviD?
Oops... in my head I wrote that they were Divx movies... on the screen I didn't... sorry!!
I am getting the movies from Newsgroups...
Thanks and sorry!!
J -
Ok... Ok... so I am new to this...
Divx what?? I didn't know I had a choice... where can I find the answer to "what"??
I guess I may have been assuming that Divx and Xvid were about the same thing... is it true that an Xvid won't play on a Divx player??
Thanks for your patience...
J -
There is a trick, push system button 2 times when playing. This can correct that picture for SOME file types....
Load the AVI in GSpot, post a screen shot.
/Mats -
XviD is MPEG-4 Part 2, DivX is MPEG-4 Part 2. Still doesn't mean that you can call XviD DivX even though they follow the same standard.
DivX has very specific profiles for standalone players. Step outside of the profile and it may or may not work.
MPEG4Modifier will tell you what quant matrix it uses.
playing divx files
By manu4ever in forum Newbie / General discussionsReplies: 1Last Post: 2nd Nov 2009, 09:10 -
DivX Movie Playing
By ghforlife in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2009, 11:38 -
problem with playing divx files on sony NS67P ?
By cccf25 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 8th Feb 2008, 08:57 -
playing divx files
By avo_aj in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Jan 2008, 06:23 -
.divx with subtiltle playing problem
By qknet in forum Software PlayingReplies: 6Last Post: 24th May 2007, 04:05
