hi guys, I have a NEC dual layer drive and I was trying to record onto Verbaitim Dual Layer media but Nero 7 only shows 4GB of space but when i use the disc INFO tool it does say Dual Layer, but still only shows 4GB of capacity. Anybody encounter this and know how to fix it?
thanks so mcuh
how much space is shown as available on a blank disc inserted and viewed in windows explorer? It does sound like firmware issue but if windows confirms available space you might need to uninstall/reinstall Nero.
check the tool if your drive is recognized as DL, then try another DL media if same then make sure your dvd drive supports DL and go for firmware update.
easy
just try to burn it, it will then work or wont, easy as that -
Is the disc DVD+R DL or DVD-R DL?
Your NEC DL burner may not support the -R DL standard.
I saw this recently on a friend's PC. He had a DVD+R DL burner. It also burned DVD±R(W) discs. He put in a DVD-R DL disc and it only showed 1 layer. It only burned 1 layer, too. I found it odd that it burned at all, but who am I to argue when something works when you thought it shouldn't at all. Sucked that we wasted a good DL disc though.Originally Posted by gastorgrab
As for the original question. Check the media and then update your firmware as everyone is suggesting. You may need to get a new version or need to reinstall NERO.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 23:52 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 14:39
