I was wondering how to remove subtitles from either .avi/.mkv files?What programs should i use?the only program i have is VirtualDub. If someone can point me in the right direction that would be great. An also does anyone know how to use Adobe Premiere?an also i'm a absouletly Newbie when it comes to using both software programs.
Cheers.
If they are embedded into the video then you might try delogo for virtualdub, however it seems to work best with still logos, like station idents, and not with text that moves or comes and goes. And even with fixed stills, it is patchy and usually leaves a blurry ghost behind.
This might give you some ideas https://forum.videohelp.com/viewtopic.php?t=280003&highlight=logo+removal
Otherwise you can crop, or live with it.Read my blog here.
Super Easy Question about COMPRESSION USING ADOBE PREMIERE PRO CS5
By BronProductions in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2012, 18:48 -
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
Exporting Premiere Pro CS4 Project - Adobe Media Encoder question
By schmickers in forum Authoring (Blu-ray)Replies: 1Last Post: 27th Jan 2012, 18:51 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
Adobe Premiere Pro 2.0 project file/autosave question
By wwervd316 in forum Newbie / General discussionsReplies: 0Last Post: 20th May 2008, 19:14
