I have a few tv movies i want to put on cd but they are in mpeg 4 format. I've tried a few programs but, nothing works. I would appreciate any help..Thaks
Results 1 to 10 of 10
Try VSO Divx to DVD
This programme can transfer mp4 to dvds directly and even burns the dvd.If there is any audio shift it will tell you how much and correct it automatically while encoding -
DivxtoDVD will create the VOBs you need. You can load these into DVD Lab Pro (demux when it asks) and add your menus.
Read my blog here.
i got mp4cam2avi and that converts the mp4 files in avi (takes about 30min) then i could encode them to everything i wanted to!!! and good quali!!!
I've been able to encode mp4 videos to mpeg-2 (and subsequently author and burn to DVD) using Avisynth and TMPGEnc Plus.
Baldrick's guide was very helpful:
https://forum.videohelp.com/viewtopic.php?t=284288
(plus a bit of trial & error on my part - no pain, no gain, right?)
Cheers,
Jim
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 09:08
