When playing an avi file (WMV3 codec), the video occasionally displayed green throughout the playback! What is wrong?
Probably a corrupted codec. You should be able to check them with DXMan. I hope you haven't downloaded any codec packs lately.
That is apparently a Windows Media Player 9 codec. Does it play properly with WMP9? -
I try to remove those codecs that stated "NO" under exist column but it doesnt remove at all!
There's a second program that is better at removing I didn't mention, Codec Sniper. You have to be more careful with it as it can remove codecs that are needed, including system codecs.
my avi files only show video intermittently, not a codec problem.
By midwestcreative in forum Software PlayingReplies: 11Last Post: 18th Dec 2009, 16:55 -
Faulty wmv3 (9) codec problem
By Darius_bd in forum Newbie / General discussionsReplies: 6Last Post: 26th Dec 2008, 17:30 -
Disable full screen for TV when playing AVI
By slav in forum Video ConversionReplies: 2Last Post: 18th Dec 2008, 23:07 -
ASF (wmv3 codec) converts without sound
By mehlkelm in forum ffmpegX general discussionReplies: 2Last Post: 9th Jan 2008, 10:05 -
I get sound and green screen when playing videos..
By nddad98 in forum Newbie / General discussionsReplies: 1Last Post: 7th Aug 2007, 17:25
