For some reason when I go to My Computer/Tools/Folder Options, the only tab that is available is the File Type. There used to be a View tab and a couple of others I can't remember. I was wondering if anyone might have any idea what has happened. I'm using XP home with all the service packs and updates.
I wasn't referring to that View tab. I was referring to setting up the folder options under Tools.
check for spyware or adware and uninstall if needed, if that doesnt work open regedit, and if there is a value called "NoFolderOptions" then either delete it or set it to 0, then restart. i havent tried this since i never had to, but it seems to work for others. hth
Thanks Duffy, will give that a try. Have check for spy and adware but haven't found any yet.
It's posible that you've got a Trojan that changed your settings.
If you need to look through all your files, you can use a great Free File Managment Utility called A43. You can get it here:
http://www.snapfiles.com/get/a43file.htmlI stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix,
WinFF 1.40 portable doesn't save folder options
By jgg in forum Video ConversionReplies: 2Last Post: 19th Jun 2012, 14:53 -
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 16:23 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 19:09 -
WPDNSE folder inside your system Temp folder????
By MozartMan in forum ComputerReplies: 25Last Post: 27th Mar 2011, 08:35 -
Win 7 folder options?
By jyeh74 in forum ComputerReplies: 8Last Post: 21st Jan 2010, 15:43
