Hello all !
Iīm new here and I really like this site !
Hereīs my problem !
I have some DIVX files here, and donīt ask me how, but the sound is distorted !
The impression that I have here is that the sound was recorded too loud !
Iīve already tried noise reduction, but I donīt have any idea how to set up a good noise reduction, so the audio is "robotic" when I process it!
The interesting thing is: When I play the file on my Philips DVD player, the DVD, and again, donīt ask me how, seens to separate this frequencies from the audio, so I listen the audio with a good quality and the noise separately. Let me try to explain this again:
When the sound is distorted, the distortion is part of the sound, on the dvd, is a separate noise.
My question is:
Does anyone knows how can I clean up the distortion ? I know that the distorted frequencies are gone forever, I just want to eliminate it from the file. Does anyone knows wich filter can I use and how the hell I set up the noise filter ?
Thank you all very much !
What you might try is to take the sound out of the file and run it through a audio editor like the freeware Audacity. You can apply some filters, maybe normalize it or apply a low pass or high pass filter. Play around with it a little and see if that helps. Save it out as a MP3 when you are satisfied. You will need to have Lame MP3 installed. (From 'Tools' <<<)
I use VirtualDub Mod most of the time. You can demux the audio out or just save it out as a WAV file and Audacity can accept either. For extracting as a WAV with VDMod:
https://forum.videohelp.com/viewtopic.php?t=280779
Then you can put it back in by selecting it in VDM and replacing the original audio.
Audio Sound Distorted
By Teac23 in forum Software PlayingReplies: 0Last Post: 1st Aug 2010, 07:40 -
Need help repairing clipped (distorted) audio
By headless chicken in forum AudioReplies: 6Last Post: 20th Apr 2010, 17:00 -
distorted audio after transcoding thru Premiere to Cleaner
By noki in forum EditingReplies: 0Last Post: 8th Aug 2008, 06:36 -
Audio distorted when converting MKV to DVD
By excite in forum Video ConversionReplies: 38Last Post: 21st Jun 2008, 11:56 -
distorted audio
By thekingbeyond in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 20th Mar 2008, 14:11
