Explain this one for me folks ...
I have two video files. One has AC3 audio and one has PCM. Fine. I usually use dvdsanta to convert and normally works fine. I converted both with santa, used dvd author to author, then copytodvd to burn both on the same dvd. The AC3 audio didnt work but the PCM one did. Strange. Changed audio settings on my dvd players and nothing. I did the same procedure with each file ALONE on a dvd and they both worked. Thats odd. tried them both again on the same dvd, the AC3 audio one dont work again.
What up wit' 'dat?
LG
Results 1 to 17 of 17
I don't know exactly what DVD Santa does when it converts (personally, I wouldn't touch it with a barge pole), however if it puts both videos in a single titleset then it is breaking the DVD spec in a way that would stop many players from playing the audio correctly. Basically, all titles in a titleset must have the same audio format.
Look in the Video_TS folder and tell me what IFO files you see.Read my blog here.
Once I made a mistake to put two video clips with different audio in one titleset with GFD. DVD Author creates two audio tracks
. One has sound in corresponding format only for the first clip and silence for the second. The other has silence for the first and sound for the second. It was a bit funny.
My video ts folder looks like this:
Video_ts 13,460
video_ts.bup 16
video_ts.ifo 16
vts_01_0 13,474
vts_01_0.bup 66
vts_01_0.ifo 66
vts_01_1 1,048,404
vts_01_2 908,196
vts_02_0 13,474
vts_02_0.bup 72
vts_02_0.ifo 72
vts_02_1 1,048,474
vts_02_2 939,334
I put the file sizes just in case
LG -
Clicky for the sticky.Originally Posted by Lucifers_Ghost"Art is making something out of nothing and selling it." - Frank Zappa
Well, this a xvid encoded video with mp3 VBR audio in avi container. Nothing unexpected. Obviously it is not ac3.
Many encoders have problems with mp3 VBR. -
Hello again,
Still having problems with an AC3 file. I have posted a screen shot again.
I have coverted it and when I try and load it into tmpgenc to author, an error saying "cant initialize the decoder."
I viewed the sticky for tmgenc problems. The only thing that stood out to me was to install the AC3 filter, which I did. But still no dice.
Any ideas?
Are you trying to load it in tmpgenc or tmpgenc DVD author ?
One is an encoder, the other authors DVDs.Read my blog here.
Sorry Gunslinger. Im trying to load it into tmpgenc dvd author after having converted with dvd santa. I've done this a billion times but just recently, its not working. I have even recently formatted my pc to make sure thats not the issue. I was wrong.
AC3 (5.1 audio files) and PCM 96/24bit stereo audio files
By joannes in forum Authoring (DVD)Replies: 2Last Post: 9th Mar 2010, 16:48 -
Convert PCM to AC3???
By ivano09 in forum Video ConversionReplies: 6Last Post: 17th Feb 2010, 13:08 -
PCM vs AC3
By Reading Bug in forum AudioReplies: 14Last Post: 1st May 2009, 05:34 -
Problem with PCM Audio track when Burning DVD
By darnhs in forum DVD RippingReplies: 7Last Post: 11th Aug 2008, 22:07 -
AC3 audio is output as PCM to my receiver using SPDIF connection
By Daft in forum AudioReplies: 8Last Post: 7th Mar 2008, 15:45
