Results 1 to 10 of 10
  1. Hi
    can anyone help me to ajust an audio problem using goldwave.
    I found that the audio in a video file is out of sync by 145 ms
    So I would extracted the audio part of this video and I would like to use goldwave to correct the audio sync by this value but I could not find this option.
    So if anyone can help me with this
    thanx a lot
  2. nobody use this software to do this kind of operation on audio sync problems ?
    cut 145ms or add 145ms silence?
  4. Ohh it would be that easy ??
    I yought I would need to stretch or shrink the audio in a certain way to gain or loose few ms...
    Can anyone help on how I can do this using Goldwave ?
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    If it's constantly out of sync with the same amount - yes, it's just a matter of cutting some off/adding some silence to the start.
    If it starts out good, but gradually drifts out of sync, you'll have to "time warp" it so it stays in sync at the end.
    Really, is 145ms that much? - Ive seen commercial movies with worse sync!
    /Mats
  6. can you help on how can i remove or add some silence at the begining of the sound file
  7. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    In Goldwave to insert: open file, Edit>insert silence>0.145 (145 mS),
    To cut out: Edit>marker>set, set the start marker for zero, set the finish marker to 0.145, Edit>cut.
    Save the file when done.
  8. Oh yeah !!
    thanx a lot for your help !!
  9. in what program did you figure out it was exactly 145 ms out of sync? that program probably has better chances of fixing this than goldwave. I'd find it cumbersome to use goldwave to fix a sync issue since it has no video support.
  10. Originally Posted by mrtunes
    I figure it out using Media Player Classic
    and I don't think it can fix audio sync problem by modifying the video file itself.
    I have been told that to solve audio sync issue I need to correct the audio (by adding silence or removing a number ms) than reencode the video using the initial video as the video source and the corrected audio as the audio source.
    If you think there is a easier way to do it I would be happy if you can share it with us ...
