Want it to be able to accept subtitles, do a menus, and motion menus.
Results 1 to 14 of 14
Scenarist
That said, DVD Workshop 2 and DVD Lab Pro can both do all of what you need and more, and for a lot less money.Read my blog here.
One suggestion would be the DVD-Lab series. Or you could just go to 'Tools' on the left and look under 'Authoring DVD' to see a few more options. <<<<<
You can spend a lot of money with a authoring program, but you might check to see what you need first.
EDIT: DVD Maestro is $5000US if you really want one of the most expensive authoring programs. -
So is Maestro the best?
Read it doesn't support VOB files!
Any others? That are professional, super good? -
guns1inger, as far as I know DVD Maestro is long gone. It's one of the more expensive authoring programs listed, though that doesn't make it the best. Just an illustration.
Scenarist is probably a better example, I just grabbed the first one.
Goldman123, as far as authoring, it depends on what you want to do. Take a look to the authoring programs listed to see what you need.
Programs like Sonic Producer are professional grade, very expensive and with a steep learning curve. Not a good choice unless you have a lot of money and time to spend, just my opinion.
EDIT: Noahtuck, sorry I edited that out, still my opinion.
I guess if someone is asking for the best, you are in the wrong place. If you are a professional, you should have already have access to the best programs and cost is not a problem. Cost is a problem for most of us, though. I like DVD-Lab, though I don't use it.
:POriginally Posted by redwudz
Yeah i saw you did that after i posted, i was like great, people are gonna wonder where i got that from
But yeah, i was going to mention even dvd lab would be better than Sonic DVD Producer as it's a bit cheaper than dvd lab pro (which i use exclusively now)
Although i was looking at Adobe Encore DVD 2.0, but for $350.00 i still dont really see anything i can do with it that i can't do with dvd lab pro unless i'm missing something ?
Adobe Encore DVD 2.0 does not even support DTS audio
Oop's, just saw it does support DTS audio, thought i read that it did not.
Oh well, dvd lab pro does and it's still alot cheaper.
http://store.adobe.com/store/products/master.jhtml?id=catEncoreDVD
But as you said, if $$ is not a problem, hook it up, but for the $$ you can't beat dvd lab pro even for alot more $$
P.S.
The link in the tools section still lists adobe encore dvd as $550.00 but on their site it is listed as $349.00. -
So if money is not a problem go with Sonic DVD Producer?Originally Posted by Noahtuck
If you have the money, hire someone experienced that has Sonic DVD Producer or other. It will take you months to get trained and good at it.
Maybe one to two years to master Scenarist. These are afterall professional programs. They are used to author commercial quality tape masters or premaster directly to the replicator.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
You will find that most reputable DVD authoring programs either don't support the use of external VOBs at all, or only do it by first demuxing the useful parts (video and audio) out to the HDD. Why ? Because the target market they are aimed at (professionals) don't generally work with VOBs, they work with video sources.
Read my blog here.
I agree, dvd lab pro is probably a better choice if you dont want a REALLY steep learning curve..........most expensive doesnt always make it "the best" it just makes it the most expensive........lets take for example, antivirus programs...AVG which is free, has been better to me than norton, mcafee, ect...........just kinda something you may wanna consider...even dvd lab pro has some rather advanced things in it that will probably take a while to learn...ive been toying with video related stuff for some time now, and there's still some things i cant figure out with dvd lab pro.....on the same page, though, it is a VERY powerful program, and isnt too hard to learn the basics....
Now this is fascinating. Goldman, I see you are currently using Sonic MyDVD, from your other post. This is about as far from what you are asking about as you can get. It works, but very limited.
Personally, I like DVDAuthorGui. Lots of options and has not crashed or produced a coaster yet, unlike DVD Lab.
Authoring a home-made DVD problem
By elmuz in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2010, 07:28 -
Which dvd authoring program could I use...
By sagat93 in forum Authoring (DVD)Replies: 5Last Post: 14th Oct 2009, 21:43 -
Authoring a DVD home movie
By vikasa in forum Authoring (DVD)Replies: 29Last Post: 30th Aug 2008, 17:29 -
Looking for a simple program to redo dvd menus for my home movies
By brycej817 in forum Authoring (DVD)Replies: 2Last Post: 24th Jan 2008, 14:31 -
Best program to create a DVD with menus for home movies???
By orbital517 in forum Authoring (DVD)Replies: 5Last Post: 12th May 2007, 21:14
