Hi All
I have a canon i560 color printer that the red has stopped up on. I had not printed color in 2 weeks and I left the tab on the top of the red tank so the ink had not came out. So when I went to print yesterday, the red is clogged up. I have tried deep cleaning, and to blow it out with air hose.
Do you guys and gals have any suggestions to get it to work. If I have to order a new printer head, do you have a good link?
thanks
Not familiar with the printer, but if you can remove the print head, soak the print nozzle part of it in warm water with a little bit of dish washing soap for a few hours. That may soften the hardened ink. Not too hot, not too much soap. Most printer ink is water soluble and soap is a good way to soften it. If it is oil based, then more aggressive cleaning may be required. Then you would run the cleaning cycle with the printer to see if it does the job. It might take longer soaking and more cleaning cycles to clean it up.
My HP printer D5360 died, looking for a new DVD printer
By stiltman in forum MediaReplies: 9Last Post: 18th Mar 2011, 23:04 -
Looking for Color Laser Printer reviews
By SCDVD in forum ComputerReplies: 5Last Post: 1st Jun 2009, 23:43 -
color laser printer advice
By lordhutt in forum ComputerReplies: 6Last Post: 11th Apr 2009, 23:06 -
Suggestions on color laser printer? REQ: Full-bleed with 11x17
By lordsmurf in forum ComputerReplies: 4Last Post: 12th Sep 2007, 15:59 -
Advice for a new printer (multifunction inket or personal color laser)
By bobogs in forum ComputerReplies: 5Last Post: 30th Aug 2007, 10:51
