  1. I ripped a DVD-9 movie with DVDDecrytor using file mode. I then went to use DVD2AVI to convert the movie vobs into one avi which I would then convert to Xvid in Virtualdub. The problem I've been running into is that then I load the vobs in DVD2AVI the pieces of the movie aren't cohesive; the beginning will be cut, the credits are missing, and in the middle the movie will just repeat from the beginning. Is this a probelm due to the movie disc being dual-layer? If so, how can I get around the problem?
  2. Rip it in ifo mode.
    Nov 2005
    And... If you're using the old DVD2AVI, might want to look at DGIndex.
