Hi, I was wondering if anyone knew what Nero program or version allows you to burn to Multiple Burners at one time? Thanks for your time.
Dayna
Results 1 to 12 of 12
Geogia Video Productions
www.georgiavideoproductions.com
"It's not what you did, it's what you didn't do." -
Okay, but where do you go to see that setting? Or does it not show up until it recognizes that you have multiple burners? Thanks
Open up more than 1 NERO when burning with mulitple burners.Originally Posted by Dayna
Originally Posted by budz
No that is not how its done, you can burn same movie or whatever to multipler burners with one instance of NERO. -
I've never done this and I've never seen the need for it but if I were to do this how is it done?Originally Posted by Treebeard
I believe you just select multiple copies, dont remember its been so long since I've done it.
NERO supports up to 4 recorders at the same time in version 6 or later -
I've selected multiple copies before and I have multiple burners installed. After the first one was completed it ejected the disc and prompted me to insert the next disc. What setting do I need to select to choose multiple burners?
I'll look into It, this doesnt show the how but the ability.
http://ww2.nero.com/nero6/en/Nero_Burning_ROM_6_prev.html -
I never noticed that radial box before. I'm going to have to try this on the next multiple burner system I assemble.
Thanks. Someone on the other forum I get on emailed me and told me how it works. I just need to get the full version of Nero, becuase I just have the one version that came with my PC and it doesnt show that you can use multple burners. I just have Nero StartSmart and Nero Express. I am going to invest in some multiple burners too. Thanks for the replies.
DaynaGeogia Video Productions
question about how to burn Nero Image
By jimdagys in forum DVD RippingReplies: 5Last Post: 4th Sep 2010, 11:06 -
Nero Recode question
By wulf109 in forum Video ConversionReplies: 1Last Post: 4th Aug 2009, 07:55 -
nero 8 question
By m-man in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2009, 13:38 -
Nero 6 audio editing question
By Rad17 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2009, 23:53 -
Nero 8 transcoding question...
By RaGuSNY in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 14:23
