Is there anyway to download movies off the interent, burn them onto a cd and then play it on the PS2. Is there like a mod chip for it?
I haven't heard of anything for the PS2 but the PS1 has an add on that allows you to play VCD's.
CanadianZ
Hitachi DV-P415U and a Sony CD-RW CRX120E -
yes there is but it takes a lot of work and i wonder if its worth it just buy a cheap dvd player
heres the link for the tutorial http://www.megagames.com/console/cgi-bin/dlps2.cgi?PS2-VCDPlayer-TUTORIAL!zip
GOOD LUCK
<font size=-1>[ This Message was edited by: daren b on 2001-12-29 16:21:42 ]</font> -
Thanks for your brilliant advice Kdiddy. Unfortunately some of us have jobs and don't have time to cycle through tons of posts when using the search functions
Your alternative would be to author vcd as dvd. Programs like tmpgenc dvd author will accept vcd mpegs and convert only the audio to dvd specs (48khz). That would be a good alternative, and generally fast too.
The other option would be to use an mpeg converter and go from mpeg1 to mpeg2 and then author it like a normal dvd. However you have to use media you know the ps2 will accept. I've heard that the ps2 isn't the most forgiving to dvdr blanks. But use what works for you.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Can I use my PS2 controller on my PS3 to play PS3 games?
By jbitakis in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 15:24 -
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 17:32 -
Can the PS2 play divx avi movies?
By amjad_z4 in forum DVD & Blu-ray PlayersReplies: 30Last Post: 14th Jul 2010, 06:52 -
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 06:14 -
LCD Monitor I can play my PS2 on?
By oroboro in forum DVB / IPTVReplies: 3Last Post: 22nd Apr 2008, 09:54
