Apologies for the basicness of this question but i was wondering if there is a big difference in the quality if i rip a dvd to avi or mpeg etc?
If there is which is the better format to do it to and what in your opinions give good results. im looking to put it on a multimedia player to play through my tv.
any advice would be appreciated. thanks
It really depends on what your goals are and what you find acceptable in terms of video quality.
If you have lots of HDD space then leave it as mpeg, no re-encoding, no transcoding ect..... I have a media player and enough HDD so this is what I do.
If you want smaller files then you can either go with lower bit rate mpeg or go with DivX or Xvid or WMV. To maintain high quality you will still need to maintain fairly high bitrates even with avi, not as high as mpeg but still fairly high. Also, keep in mind that unless you have a very fast pc you will have significantly long conversion encoding times unless you have something like the Plextor Convertx. The TV you will be viewing these files on will make a difference as well. The bigger the TV the better the quality will need to be for example.
Personally I think WMV is the best quality for a given file size but it is very slow, very long encoding times. If I do convert mpeg to avi I use the He-3 DivX codec at between 1.5 and 3.0 Mb/s
My suggestion is to list out your goals/constraints and go from there.bits
Newbie with Xbox - what s/w to rip DVD library @ highest sound/pic quality
By Snuker in forum Newbie / General discussionsReplies: 17Last Post: 13th Jan 2011, 12:37 -
Bad sound quality from avi's to DVD w/both Toast or XiliSoft DVD Creator?
By NoMoPackers in forum MacReplies: 7Last Post: 2nd Apr 2009, 03:57 -
DVD to AVI-no pic only audio??
By Reggie6966 in forum DVD RippingReplies: 4Last Post: 2nd Mar 2008, 05:17 -
quality with pic zoom in and moving background?
By video_enthusiast07 in forum EditingReplies: 0Last Post: 11th Nov 2007, 11:32 -
converting .avi (divx) to dvd and keeping original quality...
By RushMaster in forum Authoring (DVD)Replies: 15Last Post: 22nd May 2007, 14:47
