  1. hi
    is there another program like shrink thats just as fast to recode
    ive got a few files at 4.55 gb i want to shrink and dvd shrink wont recognise them
    thanks
    nuff respect
    Mar 2004
    Originally Posted by tonyburns
    hi
    thanks
    Can you give us the types of files that DVDShrink is failing to recognize? The source?
    There are other programs out there that are more or less "like" DVDShrink, however, merely supplying you with a few may not even resolve your current issue. DVDShrink is a capable ripping program; there are other very capable ripping programs. DVDShrink is also a very capable compression program; there are other programs out there that can also compress, and a few of them do this about as well as DVDShrink. DVDShrink is also an authoring program. There are other programs out there which can outdo DVDShrink in this area, since DVDShrink's authorship capabilities are pretty limited.
    However, again, your problem may be simply one of file compatibility. You may need to convert those files to a format that most rippers can read. Id so, we can suggest some programs to do this. Or, it may be one of a copy protection scheme. DVDShrink cannot handle some of the most recent new discs being released, and it is no longer being updated to be able to handle those. If this is the case, we will suggest different programs than the first example above. Your problem may be one of a dirty disc, or a bad pressing. If so, you can clean the disc, or you can return it for an exchange and ask for a new one (if it was badly pressed).
    There are other possibilities.
    So, give a bit more info, and you will probably get some advice that is "effective," instead of some vague sort of "Program X is sort of like DVDShrink is..." which may yield a program that is no better at resolving your present issue.
    -Bruce
  3. hi
    thanks for short reply bruce lol
    the files ive got were avi files recoded to dvd with winavi then come out at 4.55gb i need a program to shrink it down a bit
    dvd shrink will say invalid data in file error in one of the vobs or sometimes it will only show up one of my avi files that been recoded to dvd
    i know the files work fine because they will play ok in my sony dvd player on a dual layered dvd but i dont want to use dual layered dvds the whole time
    what other programs do u suggest
    thanks
    nuff respect
    Apr 2004
    Miskatonic U
    WinAVI strikes again . . . .
    If you have them on dual layer, why not rip them again using dvd decrypter, then shrink them. It might fix WinAVI's screw ups.
    Read my blog here.
  5. Banned
    Feb 2005
    USA
    Which other programs out there will shrink VOB Files in order to fit on a single layer disc?
  6. Originally Posted by ROF
    DVD2One
    Nero Recode
    A google search could have avoided such a question.
    Believing yourself to be secure only takes one cracker to dispel your belief.
  7. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    cool sig dv8ted2 "no evil shall escape my sight...."
  8. Originally Posted by ROF
    SolveigMM MPEG2 Requantizer. (MPEG2 or VOB input -> MPEG2 ES)
    Rejig. (File Mode, IFO Mode, Full Backup, also ability to mux and author)
    Pull! Bang! Darn!
