Hi experts. I am new to adobe premier pro. Could any one tell me how to achive the following goal. I want a clip to play like the pic bleow. part of video i want it to play like this . I am not using it as menu or any thing elese.Thanks
Results 1 to 12 of 12
I'm not familiar with adobe, (and I don't consider myself an expert
) but I want to clarify your question. Are you looking for something to mask your video with the above shape or do you want your video to be distorted into that shape?
Buy My Books -
Thank u for u reply. I think i want the video to distorted into that shape. Hope some adobe premier expert help me out here.ThanksOriginally Posted by gadgetguy
On the other hand, the title "frame shots demo" implies that it's merely an alpha mask.
well that demo thing is because i use a demo software to take a snap shot not any thing else!!Originally Posted by kschang
You can do this in After Effects 6.5 using the Bezier Warp effect. I don't think that's available on Premiere though.
A guide for this using freeware is already on way ...
Up in a week's time . -
Many thanks for u reply. could u upload the tutorial as soon as u can. I still wait for it!Originally Posted by Bjs
@ method: There's two possibilities here...
1) The video is actually distorted to give the "bowed" effect top and bottom. As someone has already pointed out, WinMorph ( www.debugmode.com/winmorph ) should be able to do this. It's free and can be a plug-in to Premiere Pro.
It doesn't appear to be in the "Tools" list, so I've submitted it.
2) The video itself isn't touched, but a suitable shape is laid over the top, and the video plays through a "gap" in the middle.
This is easily achieved by making the "shape" in something like Photoshop with the "gap" in the middle only needing to be a transparent background. That way, no need to mask - alpha or otherwise.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
How do you place an image directly INSIDE a video clip?
By Devilsadvocate in forum EditingReplies: 19Last Post: 27th Feb 2012, 12:27 -
Play Xvid clip on a HD TV vs SD TV
By Cazz in forum Newbie / General discussionsReplies: 2Last Post: 12th Feb 2011, 14:51 -
DV video clip won't play anymore
By cajustse in forum Newbie / General discussionsReplies: 3Last Post: 11th Jun 2009, 15:57 -
xbox360 won't play this avi,, codec info inside
By sance in forum Media Center PC / MediaCentersReplies: 11Last Post: 24th Dec 2008, 13:11 -
How to play a HD clip on my standalone HD player?
By Ingolf in forum DVB / IPTVReplies: 15Last Post: 24th May 2007, 13:43
