    Oct 2005
    Europe
    Hi all i saw one dvd intro clip that looks like pic bleow. Where i could insert text and pic inside it. could any one tell me where i can get it or how i can create one.Thanks
    USA
    That could be from a menu or motion menu (If it moves) from a DVD authoring program like DVD-Lab pro or a similar high end authoring program. Or even a menu template from TMPGEnc DVD Author.
    You could do a Google search for 'DVD menu templates' and you may find a similar one.
    Oct 2005
    Europe
    Thank u for u reply.well it is not menu or motion menu . It is just a advertizment clip!
  4. Mod Neophyte redwudz's Avatar
    USA
    If you have a decent sceenshot of it, you should be able to use it as a background for your menu. Not sure of how to do that, but a authoring program should be able to use a file like that if it's in a acceptable format.
    Oct 2005
    Europe
    well i do not want as background of dvd menu. I am looking for that clip. I just put a snap shot.Thanks
  6. I just put a snap shot.
    From where can you put a snap shot if you don't have the clip?
