hello everyone,yet another noob(ish) here.
just wondered if anyone can help?.
i am experimenting on making a dvd(using svcd2dvd).
i can make the dvd fine,with menus the way i want etc,but was wondering if there is a way of putting something at the very begining before the menu screen?,i.e an animated logo or picture or something if you get my drift?.
i have seen dvds before where the persons name scrolls across the screen just before the menu screen,would love to be able to do something similar..
THANK YOU IN ADVANCE FOR ANY HELP OR ADVISE![]()
You do that with a authoring program. A simple one is TMPGEnc DVD Author. If you need more advanced and flexible authoring programs, (And more cost along with a steeper learning curve) you could use ones like the DVD-Lab authoring programs. There are three versions in 'Tools' under 'Authoring DVD' to the left. <<<<<
Most all the mentioned programs have trial versions, so you can experiment a little before you purchase one. -
ok thanks for the reply,dont know if i explained properly?.
i alreday know how to create a dvd,make menus etc.
i wanted to make an animation/logo etc and add to the very begining of the dvd.before the menu i have made appears.
Requesting help to make an animated gif!
By kSOS in forum Newbie / General discussionsReplies: 6Last Post: 5th Apr 2010, 13:39 -
How to make a short animated movie/video clip? Example included.
By UmmAddan in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2009, 09:36 -
How do you make screen size bigger on Philips dvd model DVP642?
By jkristoff in forum DVD RippingReplies: 9Last Post: 23rd Jul 2008, 04:33 -
how to make dvd that does not fill up the screen!
By turbochargedRS in forum Authoring (DVD)Replies: 13Last Post: 20th Jun 2008, 23:37 -
Is it possible to make animated buttons and info box?
By leffe in forum Authoring (DVD)Replies: 5Last Post: 17th Sep 2007, 17:53
