It says it doesnt support the usual subtitle files, any help?
Results 1 to 10 of 10
Doesn't the manual say?
/Mats -
It says it doesn't support "the usual subtitles", but doesn't go on and say what it supports?!? Sorry - someone familiar with MyDVD has to pitch in, as I've no idea!
/Mats -
Well figured something out.
Any1 know how to convert .srt to .txt? -
Figured it out.
Can some1 tell me what program tells me all the information on the .sub/.srt File? -
AFAIK, a srt basically just contains the text to display along with when to display it:
"10" is the order of the textCode:10 00:00:52,072 --> 00:00:57,575 This is the text to display
Then a line with when to display and when to remove the text. This is on at 52 seconds and 72 thousands and off at 57 seconds, 575 thousands.
Then the text itself.
Sometimes, you see an ... around the text too - that's italics, but not all players use it. I mostly delete all these. That's all there is to a .srt really.
/Mats -
Well I mean like font size and stuff, because on Sonic DVDit Pro 6, the subtitles come out all messed and you have to configure the subtitles in the program. Like height width and all that stuff
srt doesn't contain any info about font, weight, size, positioning and stuff - it's totally up to the application that renders them.
/Mats
Which dvd authoring program could I use...
By sagat93 in forum Authoring (DVD)Replies: 5Last Post: 14th Oct 2009, 22:43 -
A program taht's is realtively simple like TDA & MyDvd. but more Robust
By Denvers Dawgs in forum Authoring (DVD)Replies: 5Last Post: 24th Jun 2009, 11:35 -
which dvd-authoring program is better?
By siluet in forum Authoring (DVD)Replies: 9Last Post: 8th Oct 2008, 15:25 -
The Best DVD Authoring program
By Random490 in forum Authoring (DVD)Replies: 6Last Post: 12th Dec 2007, 05:10 -
large file size when importing small video clips into Sonic MyDVD
By artistream in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2007, 20:48
