    Jan 2006
    Folks need some help on this one,
    I have video & audio ts files that I want to burn to a dvd via toast 7. I am trying to play it on my Sony dd player. I use create DVD with Video TS option under toast and the disk won't play.
    I also created another disk as a data copy and neither would play on a standalone dvd player.
    Any thoughts? The DVD does play on the mac.
    Dec 2003
    Eugene, Oregon
    If the VIDEO_TS folder has not been modified - nothing was deleted from the original source DVD - then you select the VIDEO_TS folder using the DVD video from VIDEO_TS setting in the Toast Video window and burn your DVD.
    If it has been modified then you need to replace it with one that is a full disc extraction, or do the following:
    -Place the VIDEO_TS folder on the desktop
    -Select DVD video as the Toast format
    -Click the Media button to enter the Toast Media Browser
    -Choose DVD with the top button; when the video appears in the lower window, go down one level using the lower button.
    -The titles in the VIDEO_TS now appear in the lower window. Drag any you want to the Toast Video window. Toast extracts the MPEG from the VIDEO_TS folder.
    -Do any editing you want for the Toast menu and you're ready to burn your DVD.
