Hi,
How can I convert movie trailers in the Quicktime mov format to a format that will allow me to watch them on my DVD player...?? Thanks for any help...
You could remux to mp4 to avoid issues, then just use AVISynth with directshowsource() to frameserve to your favourite encoder or try loading directly if it supports input via dshow (TMPGEnc does). Apple's AVC decoder is much slower than CoreAVC, Nero's, ffdshow, etc. So encoding that way should be much faster.
Could also just feed the mp4 into something like DivXtoDVD. The mov may also work, the video definatly should, but the audio probably won't since it is stored differently in mov to mp4.
QuickTime MOV to MPEG2 too dark
By bgtrix in forum Video ConversionReplies: 1Last Post: 16th Mar 2012, 12:36 -
Problem with converting MOV to MPEG2
By encAmateur in forum Video ConversionReplies: 5Last Post: 18th May 2011, 03:56 -
MOV to MPEG2
By 6079 in forum Video ConversionReplies: 0Last Post: 3rd Sep 2010, 06:28 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 08:42 -
Trailers MOV format -- How to decode/demux/trancode to .MP4 ? [Solved]
By vhelp in forum Video ConversionReplies: 27Last Post: 21st Jun 2008, 15:00
