Hello,
I burn DVD with success on the following medias :
- Verbatim DVD+R 4x code MCC
- Verbatim DVD+R 4x code YUDEN000
But on Verbatim DVD+RW code MKM, burning of a DVD vidéo is OK, I can read this DVD on the standalone DVD reader of my TV set, but not on the reader of my computer (it looks like if the DVD was empty). I use Nero and in the last tab of burning section the option "DVD-Rom Spécification" is not selected is it the reason of my problem ?
Finally it is not possible to burn DVD Vidéos on :
- Verbatim DVD+R 16x code MCC
Im using a Cibox DVDRW IDE1008 writer with firmware 0159, is it necessary to upgrade it to the last level : firmware 0060 ?
My version of Nero is 6.0.0.16, is it necessary to upgrade it to the 6.6.0.18 ?
For the Nero specialist, this is the last Nero log of a failed burn on Verbatim DVD+R 16x
In advance, thanks for your help and support.
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 17/06/2003 14:25:04
Version de Nero : 6.0.0.16
Graveur : <DVDRW IDE1008> Version: 0159 - HA 1 TA 1 - 6.0.0.16
Pilote d'adaptateur :<atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM : < BDV316B >Version: H1.0 - HA 1 TA 0 - 6.0.0.16
=== Scsi-Device-Map ===
DiskPeripheral : ST360020A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : BDV316B atapi Port 1 ID 0 DMA: On
CdRomPeripheral : DVDRW IDE1008 atapi Port 1 ID 1 DMA: Off
=== CDRom-Device-Map ===
BDV316B D: CDRom0
DVDRW IDE1008 E: CDRom1
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 255MB (261684kB)
Free physical memory: 72MB (73880kB)
Memory in use : 71 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
28.1.2006
Compilation UDF/ISO
10:58:58 #1 Phase 112 File dlgbrnst.cpp, Line 1843
Réallocation des fichiers DVD-Vidéo commencée
10:58:59 #2 Phase 114 File dlgbrnst.cpp, Line 1843
Réallocation des fichiers DVD-Vidéo achevée (aucun fichier modifié)
10:58:59 #3 Text 0 File Isodoc.cpp, Line 5907
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
10:58:59 #4 Phase 111 File dlgbrnst.cpp, Line 1843
Classement des fichiers DVD-Vidéo
10:58:59 #5 Text 0 File Reader.cpp, Line 118
Reader running
10:58:59 #6 Text 0 File Writer.cpp, Line 127
Writer DVDRW IDE1008 running
10:58:59 #7 ISO9660GEN -11 File geniso.cpp, Line 3861
First writeable address = 0 (0x00000000)
10:58:59 #8 ISO9660GEN -11 File geniso.cpp, Line 3861
10:58:59 #9 Text 0 File Burncd.cpp, Line 3169
Turn on Disque entier, using DVD media
10:58:59 #10 Text 0 File DlgWaitCD.cpp, Line 230
Last possible write address on media: 2295103 (510:01.28)
Last address to be written: 1483167 (329:35.42)
10:58:59 #11 Text 0 File DlgWaitCD.cpp, Line 235
Write in overburning mode: FALSE
10:58:59 #12 Text 0 File DlgWaitCD.cpp, Line 1878
Recorder: DVDRW IDE1008, Media type: DVD+R
Disc Manufacturer ID: MCC, Media Type ID: 004, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
10:58:59 #13 Text 0 File DlgWaitCD.cpp, Line 393
>>> Protocol of DlgWaitCD activities: <<<
10:58:59 #14 Text 0 File ThreadedTransferInterface.cpp, Line 769
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 1483168 (1483168) = #1483168/329:35.43
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1483168 blocks [DVDRW IDE1008 ]
10:58:59 #15 Text 0 File ThreadedTransferInterface.cpp, Line 938
Prepare recorder [DVDRW IDE1008 ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 3037835264, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
1483168 | lead-out | 1 | 0x00 | 0x41
10:58:59 #16 Phase 24 File dlgbrnst.cpp, Line 1843
Début de mise en cache des fichiers
10:58:59 #17 Phase 25 File dlgbrnst.cpp, Line 1843
Cache des fichiers terminé
10:58:59 #18 Phase 36 File dlgbrnst.cpp, Line 1843
Début de gravure à 4x (5*520 Ko/s)
10:58:59 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2136
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
10:58:59 #20 Text 0 File Cdrdrv.cpp, Line 7909
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 07 4D 43 43 00 00 00 - 00 00 30 30 34 00 38 23 ..MCC.....004.8#
54 37 12 02 54 6C 02 92 - 5F 15 15 0B 0B 08 08 01 T7..Tl.._.......
19 1B 0C 0C 0C 0D 01 00 - 00 00 00 00 00 00 00 01 ................
10:58:59 #21 Text 0 File DVDPlusRW.cpp, Line 1484
Set Booktype to DVD+R (10), set mode 'next writes' (2) on DVD+R media, return: -1046 -> FAILED!
10:58:59 #22 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 9:29,834 (569834ms) -> OK
10:58:59 #23 Text 0 File DVDPlusRW.cpp, Line 554
Start write address at LBA 0
DVD high compatibility mode: Yes
11:37:25 #24 Text 0 File WriterStatus.cpp, Line 113
<DVDRW IDE1008 > start writing Lead-Out at LBA 1483168 (16A1A0h), lenght 0 blocks
11:37:25 #25 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
11:37:49 #26 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
11:37:49 #27 Text 0 File dlgbrnst.cpp, Line 1703
11:37:49 #28 Phase 37 File dlgbrnst.cpp, Line 1843
Gravure terminée avec succès à 4x (5*520 Ko/s)
Existing drivers:
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29/08/2002 09:27:50 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Results 1 to 1 of 1
Verbatim RITEKF1, is this a bad burn?
By kira1985 in forum MediaReplies: 1Last Post: 19th Dec 2011, 10:58 -
Verbatim DVD+R 100 pack vs. DVD+R single jewel case
By GSP_87 in forum MediaReplies: 6Last Post: 13th May 2011, 06:00 -
Burner can only burn to Verbatim Media, but not anymore...
By iownju in forum MediaReplies: 6Last Post: 19th May 2010, 06:53 -
Canadians - Verbatim DVD+R and DVD-R on sale Source at Circuit city
By victoriabears in forum MediaReplies: 1Last Post: 19th May 2008, 21:36 -
Verbatim DVD+R DL burn issues with Nero and ImgBurn
By prvittal in forum Authoring (DVD)Replies: 7Last Post: 21st Aug 2007, 20:42
