I'm looking for suggestions for a nw DVD recorder. I use it primarily for recording sporting events, so it's important that the recording quality is good enough that I don't get those pixels around the players when they move. It must also be able to record a RW that is compatible with TMpeg DVD author and if it's possible, have that fine tuning option, where I can set the quality to the length of the recording instead of a straight one hour, two hour, etc. quality mode.
I've been using a Phillips for a while now, but it's very basic. I'd like to get something a little better. I tried a Cyberhome just for kicks and it was horrible, and TMpeg wouldn't rcognize the files.
Thank you for any help you can give me.
I'd recommend the Pioneer also. I have a 633. The EPG can get irritating, but you get used to it.
It works well with cable systems.
I would highly suggest the JVC DR-M100S DVD recorders. Pioneer models would be a good runner-up choice.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 14th Mar 2008, 00:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 19:14 -
Features
By Jedi_Knight in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 29th May 2007, 19:29
