  1. Can anyone recommend a DVD player that allows you to slow down the picture and still hear the audio track? Thank You
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    None that I have seen. Most likely because of the way digital decoding works, there is no way to change speed like with analog sound, it is set to decode at a specific speed.
    Google is your Friend
    Mar 2013
    Panasonic is the ONLY manufacturer that makes DVD players that have the ability to play DVD's in slow motion with sound. The model #'s are DVD-S29 & DVD-S52. I have a model for sale for $150. It also plays at a fast speed with sound. It actually has 9 different speeds, normal + 4 slow speeds & 4 fast speeds. Email me at jbanks19@hotmail if you cannot find one on the internet.
