Hi,
After my motherboard failed, i rebuilt on a different board, and had to install windows ME (as my 'xp restore disk' would not allow installation on the new board) I installed Powerdvd 6 as the default player, which mostly works ok, (but doesn't play everything anymore..)
When i look in 'my computer at the 'properties' of both my CDwriter and DVDwriter drives, it refers to them both as simply 'compact disc' and file system 'RAW' it doesn't mention a DVD region.In device manager, it recognises both drives make and model, but again no mention of region code.
My usual method of dvd backup, is using DVDshrink/DVDdecrypter, which worked perfectly with xp. But a trial attempt with my current setup, wouldn't play in Powerdvd (although all my previous 'XP' discs play fine)
All motherboard drivers are installed. Neither drive, came with installation software, and both worked fine 'out of the box' with xp..
I'm obviously missing something that i need.
My full system details are in my profile....Thanks![]()
GO FROM ME SUMMER FRIENDS AND TARRY NOT
PowerDVD by default is dvd (mpeg2) file playing software. If you are having trouble with avi files, for instance, it is because you do not have the proper codecs installed.
As for the device description, XP and 98/ME have different ways of naming devices/drives. It's been so long since I've used 98 that I don't recall where the region code information was stored, I seem to recall the player software displaying the region code or using drive tools like Nero speed.
Your ripping issue could be related to file size and disc format limitations (Fat 32 as compared to NTFS), especially if you are working with dvd images (over 4 gig).Google is your Friend
Can't Stop Magnavox DVD Recorder TITLE Page from Playing Recording
By Novice20 in forum Newbie / General discussionsReplies: 19Last Post: 7th Sep 2011, 11:00 -
Major Video Playing Problems..
By SpazRaven in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2011, 15:43 -
Have major problems with dvdauthorgui
By blue-eyed in forum Authoring (DVD)Replies: 1Last Post: 25th Apr 2008, 23:05 -
What to do with ISO, trying to rebuild it in DVD RB?
By willhenderson in forum Newbie / General discussionsReplies: 2Last Post: 29th Nov 2007, 06:02 -
Extract content from damaged DVD and rebuild
By cheerful in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2007, 21:47
