I've got a Pioneer drive, not sure of the exact model off the top of my head, but it probably doesn't matter.
I've been using the drive for about 3 months and have always ripped at 10x. Suddenly I've dropped to ripping at about 2.7x for no reason. I checked the DMA and all that, everything seems fine and I've not changed any settings or anything in what I'm doing. Anyone else experience this?
this recently happened to a friend of mine..
his problem was a combination of spyware + fragmentation.
This can also be related to the particular dvd you are processing .
It is normally struck where the release was produced on low speed media .
To make sure it's not spyware use adaware se .
For virus and trojan's , use avg antivirus free .
If they find nothing , locate a dvd you original worked on where the speed was at the original speed you were getting .
If they now prove slow , the problem is with aspi layer .
Try using the force aspi pack , that should bring it up .
The new force aspi package creates a backup of the original , so there is no problems with returning system back to previous condition .
Daemon Tools can slow rip speed
By ocgw in forum Blu-ray RippingReplies: 8Last Post: 11th Nov 2013, 11:07 -
HDV Video >>>>> Use Non drop frame or drop frame and why?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2010, 18:30 -
Pioneer BDR-205BK rip speed
By art305 in forum Blu-ray RippingReplies: 7Last Post: 22nd May 2010, 10:55 -
Converting drop frame timecode to non drop frame timecode, and vice versa
By picrade in forum ProgrammingReplies: 1Last Post: 1st Mar 2008, 04:22
