hello people,
will i need a different DVD writer to write a DVD9? this will be the first time will be burning a DVD9.. if i do need a different one, then which one would u suggest?
Since you do not state what drive you already have, and my crystal ball does not seem to be working today or any day for that matter, there no way to really tell now is there?
Yes, you do need a DL DVD R/W drive.No DVD can withstand the power of DVDShrink along with AnyDVD! -
Nope. All you need is a sharpie marker to write on a DVD9. If you want to burn information onto a disc than you'll need a drive capable of that. Since your profile doesn't list any drive I can only assume your machine does not have any optical drives. My suggestion is to buy a .79 cents sharpie and start writing on DVD9's today.
hey thanks! hope your crystal ball starts working in full swing!...
An eye for an eye makes the whole world blind - Mahatma Gandhi -
Well,,,, Maybe my Crystal Ball statement was a bit rude,,, but think about how you worded your question. No one reading your ?? has any clue how they should answer it. The second repply to it is an good example. Yes, you need to install a DVD R/W drive. Any moder drive this day will also be a dual layer capable unit. For best results stick to Verbatin DL Media and is you are backing up DVD movies use DvdDecrypter to rip to an ISO and the same program to subsequently burn it back to your DL media. Should be a 1:1 copy and look as good as the original. If you are attempting to creat movies shot by you to DL then you need a good authoring program that will place the layer break in the correct position so you do not have problems with your player later
For DL you need a DL writer, sure, but if you write +DL, you need a +DL writer.....
Btw, DL doesn't play in all dvd players.
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 11:37 -
DVD9 to DVD9 1:1 Copy
By Lastman369 in forum DVD RippingReplies: 5Last Post: 12th Jan 2010, 13:48 -
DVD9 to DVD9 2 angles layer break problem
By JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 19:17 -
DVD9 to DVD9 blank
By cadlewv in forum DVD RippingReplies: 7Last Post: 27th Dec 2008, 18:15 -
having trouble backing up dvd9 to dvd9
By Chunking in forum DVD RippingReplies: 9Last Post: 13th Oct 2007, 20:34
