Hello , I just started downloading the HD trailers off of Apple in hopes of converting them using tmpge and then making them to where I can view them on dvd, Making myself some home theater demos,
so far when I open the program and click add file , I can add the mov trailers that are only 2 channel sound, however , when i try to add a hd trailer such as Chronicals of Narnia, or Harry POtter or the other 5.1 sources I have, the program says it cant add the file or read it.
is this because its the trial version
Im wanting to buy the real version if this is the case, Its just Im wanting to make sure that this is what it is before I spend 60 bucks on the program and then find out I cant convert 5.1 material.
also. after running it through this program and then through dvd author from pegasys , will the quality of sound and picture be good on dvd ,
alot of cheap converters for avi files and such in the past always dgrade the quality significantly , The whole purpose of me wanting to do this is to provide myself with a home made home theater demo disc to show off my sound and projector to my friends
Results 1 to 24 of 24
noone knows?
I hope its just the trial , if noone has responded by tomjmorow I will just go ahead and buy the full version and see what happens -
Have you checked the website to see what the software publisher says? As it's a trial, I'm betting that 5.1 support isn't built into the free version. And if you do go ahead and purchase it, likely you may need soe sort of add-on or plug-in to make it read 5.1 audio anyway.
Good Luck and post back with what you discover!
Cheers!
TTWC"I've got a present for ya!" - TTWC -
ok ive boght everythign and evidently it was for nothing , because it still wont open up any trailers that have more channels than 2
What TaoTeWingChun said; To work with AC3 in TMPGEnc Express, you need to buy the plugin, the same applies to the regular TMPGEnc encoder.
http://www.pegasys-inc.com/en/product/tsp_ac3.html
And it will only do 2 channel, not 5.1.
But if you extract out the 5.1 audio from the original file, you can then add it to the DVD during the authoring stage and avoid messing with TMPGEnc's plugin altogether. The plugin requires periodic contact with their company over the internet to keep using it, another reason I don't like it. -
hey thanks for responding
so how do I extrack the 5.1 audio from the quicktime mov file. ?
and i guess it has to be done before I add the movie to tmpgenc , so how do I do that?
and How do I add to the dvd at the end ?
im really wanting to be able to do this.
I have some really good 5.1 trailers -
MarineRules,
That's what the 'How To...' guides on the left hand pane are for. If you look for "Mov to DVD' in the conversion pull-down I'm sure you will be able to locate what you're looking for.
In case you have difficulty searching for something useful, I can point you here for starters:
http://www.dvd-guides.com/content/view/55/59/
Give it a thorough read and then do a search in the forums for 'quicktime audio extraction', for example.
Best Wishes!
that link didnt help any considering i mentioned that the tmpgn isnt going to work ccause it doenst do 5.1 sources, i will keep looking i guess, ive been working on thiws for 3 days now
Looks like someone figured it out, and that was a 5 second search on my part . . .Originally Posted by DRP
Do a Forum search, as I did, using something like 'extract audio from MOV', you should see numerous topics.
Cheers!
marinerules : you have a bigger problem that simply trying to demux the 5.1 audio from these trailers. The audio is not AC3, which would make life simple, it is AAC. There appears to be only two programs that support the extraction of AAC audio - belight and goldwave - and I can find nothing that leads me to believe they will either convert to AC35.1, or even demux back to mono elements for you to encode elsewhere.
Super can also process MOV with AAC, but you get 2 channel AC3 output.Read my blog here.
IM so aggravated, I guess im just nott going to be able to do it , I mean I dont know why they make it this difficult
its not that tmpgnc wont read my files, i have the plugins ec.t
it wont read the video or audio or NOT HING on a mov that has 5.1 sound
it only works with 2 channel
it looks like its impossible to transfer mov to dvd using the 5.1 that my hd trailers have, which i dont understand cuase I have heard of people d oing this -
If TMPGenc isn't even loading the video, then I'd say you have bigger problems. Have a look at the guides and see what other conversion(s) might exist that would allow you to keep the video and 5.1 audio intact and then use DVD Lab Pro to preserve the 5.1 audio. TMPGenc DVD Author doesn't handle 5.1, so you are using the wrong authoring program to begin with.Originally Posted by marinerules
Use the guides and see what tools will enabe you t move from piece to piece, ultimately resulting in your final DVD output.
Cheers and happy hunting!
ok ive had a little success
for example
quicktime trailer hd,
Chronicals of narnia.
i exported the audio out and saved it as a wmv, and then I exported the video
then I ran through tmpgnc then i ran it through dvd author
the audio is lpcm , and sounds terrible, you cant hear them tlaking in the trailerl
so i guess I have it in other words, its just I need to know how to transfer this 5.1 aac audio to a file that can be read on the dvd -
A google for AAC to AC3 turned up this post http://forum.doom9.org/showthread.php?p=666230
Read my blog here.
Great tip, Guns1inger! Looks like MarineRules can do the cnversion using freeware tools!
Now, how about an authoring program? I recommended DVD Lab Pro for that - have you an alternate he can use, maybe on the cheap?
Cheers!
The only free authoring program I know of for windows is DVD Author and it's associated GUIs. I use DVD Lab Pro myself.
Read my blog here.
Great minds think alike, eh?
Thanks, guns1inger!
Cheers!
If you remux from mov to mp4 using mp4box/yamb, the files will be more compatible. Alot of mov/mp4 parsers will have trouble with aac in mov, especially if it is 5.1. The same parsers mostly handle it fine in mp4. For instance ffmpeggui should be able to convert fine from the mp4, but not from the mov.
i will try that progrma but first i have a friend I have found on the inernet that owns a trailer website , he is oging to be sending me a very expensive program, that will do this ,
you extract each audio channel out of the mov as a wmv and this program puts it back together for ac3
im just wanting to get it from him -
I wouldn't discuss the particular details of what software costs and how you'll be getting it - that's grounds for being warned about warez . . .
AVCHD viceo with .MTS ending cannot be read by Quicktime/ final cut express
By johsch in forum ffmpegX general discussionReplies: 10Last Post: 26th Nov 2008, 15:01 -
DVD to Quicktime .mov / Aspect Ratio Problems with DVDxDVPro
By accumulator in forum MacReplies: 3Last Post: 22nd Sep 2008, 07:45 -
Thoughts on Tmpgenc Express 3.1.5.82 Trial
By Batfink in forum Video ConversionReplies: 15Last Post: 30th Oct 2007, 02:17 -
Quicktime to Windows MOV-mpeg-4 conversion problems?
By Simone in forum ffmpegX general discussionReplies: 4Last Post: 16th Jun 2007, 07:50
