I installed PowerDVD 6.0, but realized that subtitles are displayed over the image when in fullscreen, not in the lower black bar like regular dvd players do. So, do you guys know of any dvd player software that allows you to set subtitles in the lower black bar, or somewhere in between.
I need this because my regular dvd player does not convert from pal to ntsc, so the only way I'm able to see these dvds is connecting my pc to my television set, using the dvd-rom. But subtitles are displayed over the image using powerdvd
Uh... Subtitles are a DVD are BITMAPS (subpictures if you want the technical term). They cannot be repositioned dynamicaly. it's not like text that can be adjusted in font and size and all that.
So what you're asking is not possible, not without modifying the source. -
Are you SURE they are in different positions for the same movie depending on the player? Give an example, please.
Software DVD Player - Forced Letterbox
By GeorgeW in forum Software PlayingReplies: 3Last Post: 9th Nov 2011, 06:00 -
What software DVD player most closely mimics a tabletop player?
By sdsumike619 in forum Software PlayingReplies: 1Last Post: 16th Sep 2010, 16:08 -
Question why I can't install this DVD player software
By jimdagys in forum ComputerReplies: 3Last Post: 11th Oct 2009, 17:42 -
What is your choice for a DVD Player software??
By videobruce in forum Software PlayingReplies: 10Last Post: 31st Dec 2007, 07:56 -
DVD player software not working.
By copiador in forum Newbie / General discussionsReplies: 8Last Post: 18th Jun 2007, 21:09
