    Jan 2006
    Has anyone tried to hook an amp up to a capture device to record like a guitar solo or something. I am afraid that i could overload the device and then blow it.
    -Thanks
    Nov 2005
    Think there's a bunch of devices, some inexpensive designed to go between guitar & line-in. Think you should also be able to use some mixers, & micing your amp has been popular enough that devices & software have been developed to imitate it. Check out what they've got over at musiciansfriend.com
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    You can't beat having one of these small mixers next to the computer. The Eurorack is a cheaper knockoff of the famous Mackie design.
    http://www.musiciansfriend.com/product/Live/Sound/Mixers?sku=631238
    http://www.musiciansfriend.com/live/navigation?q=Mackie
    http://www.kiva.org/about
    Oct 2005
    666th portal
    don't you need something like this also -
    http://www.musiciansfriend.com/product/Guitar/Effects?sku=480208
    to make the guitar sound ok?
