Let's say Get any .avi or .mpeg and Burn it as a DVD, Expanding the file to 4.7 Gigs.
Will the Video Quality be better from the original video on that file?
Same question for VCD
No, not by just changing the pixel arrangement. The same image can be "projected" to any pixel arrangement. You can easily degrade quality with lower resolution but you can't enhance quality with more pixels.
http://www.kiva.org/about -
Quality of output is limited by the quality of the source.
A long time ago, before computers, they used to say,"you can't make a silk purse from a sow's ear"Originally Posted by lordsmurf"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
Didn't get a straight out answer...
If I burn lets say 4 anime Episodes on a DVD, instead of 13 on a Data DVD (totalling up to about 2 gigs), Will the 4 episode DVD have more Quality? And/or Look better? -
Depends.Originally Posted by Goldman123
On a regular DVD player the 4 episodes DVD will look much better -- because it won't even play the 13 episodes on data DVD.
On a player that can play MPEG 1/2/4 files on a data DVD the picture quality may be worse or better. It will depend on the files themselves, how the player handles the files, and how you convert them. -
If your player can playback Divx files from a data DVD then there is little, if anything, to be gained from converting them to DVD. As has been pointed out, simply adding bitrate does nothing to improve quality. If it cannot, and your choice is VCD or DVD, look at the resolution of the original, read the What is DVD page (top left corner) and find the closest fit resolution. If your anime is full screen, you may find you can fit 7 or 8 episodes on a disk at half-D1.
Read my blog here.
Does H264 give you the best quality results for the filesize ?
By Bansaw in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2011, 12:51 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
DVD ripping: does DVDFab give the best picture quality?
By Tom80112 in forum DVD RippingReplies: 25Last Post: 21st Feb 2010, 06:24 -
Mpeg4 Settings for TMPGenc give poor quality for motion.. see pic's
By drewzor in forum Video ConversionReplies: 14Last Post: 13th May 2009, 09:37 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33
