Hey guys i have several .avi files that i want to convert to Palm tx my idea is just to shrink the size of the movies because they are about 1.2 gb >how can i do that with ffmpeg i just want to shirnk the size without altering the quality
thanks a lot
daniel
IF you buy the Kinoma Video Player/Producer. Waste of money, really.Originally Posted by Case
You need to find your screen dimensions, so you keep as much as the original will fit on the screen. Then choose "MPEG4 [.AVI] ffmpeg]" from the video tab and fill in the video res. info.
Ought to work.
but ,do you have any setting in mind which can help me do it,i just know that the TX is 320x 420.But how can i convert with ffmpeg?or rather how can i make it smaller?
There is NO WAY to compress without loosing quality (as a general rule)
However, there are ways to make sure that you can not notice the loss in quality. (Recompressing to the exact screen size, bit rates, etc)
Encode the video with the default video setting (MPEG4 [.AVI] mencoder) with the screen size plugged into the Video tab. (You'll have to hold your palm sideways). Make sure to click "Best" so you don't encode with a too-high bitrate.
Converting to avi keeping same screen size
By Dungogvolts in forum Video ConversionReplies: 18Last Post: 15th Apr 2012, 21:57 -
How to make an AVI better quality (keeping output still as AVI)?
By Dogpoundz in forum Video ConversionReplies: 15Last Post: 22nd Sep 2011, 01:12 -
Converting DVD to AVI - keeping subtitles
By Matthew1404 in forum DVD RippingReplies: 2Last Post: 11th Mar 2011, 17:48 -
Keeping size in video converted from AVI to MP4
By Chocky in forum ffmpegX general discussionReplies: 5Last Post: 12th Dec 2008, 14:42 -
[Help] avi to wma keeping avi quality?
By Riddick51PB in forum Video ConversionReplies: 4Last Post: 26th Jun 2007, 19:13
